Thanks in Advance.
Wilks
MinorMatt wrote:As mark says there are no glow plugs, what you are looking at are the injectors.
Try an oil change before winter - these engines don't like starting win winter with thick old oil
MinorMatt wrote:try putting a jump lead between the - on the battery and the lifting eye on the engine block (clean the lifting eye up a bit first to make sure there is good electrical contact)
When its cold the starter needs more current, and if the earths are marginal that would explain the problem!
Do you know what grade oil you used?
wilks wrote:MinorMatt wrote:try putting a jump lead between the - on the battery and the lifting eye on the engine block (clean the lifting eye up a bit first to make sure there is good electrical contact)
Hi .
thanks for that,the oil was 15w 40 (Total high performance).
I will try the jump lead thing next time it won't start but have other issues on right now with a broken cam belt /bent pushrods.
cheers
Wilks
chilledphill wrote:intresting one with the earth lead to lifting eye , will try that tomorrow on my mk3 89. really must get on and do service 2, and get some decent oil and filters in as it all makes a huge difference to starting on cold mornings in the mk3. but as for most in jan no cash boooo!!!
wilks wrote:I thought 5w 40 was just 5w 40 or is fully sin differant??
Wilks
