Loss of clutch
Loss of clutch
Postby sm0129 » Tue May 16, 2006 11:07 pm
Hi
Hopefully someone can offer some advice. I have a 95 smiley Di.
Occaisionaly when depressing the clutch I hear a noise, which sounds like a spring has come loose. When this happens I am unable to change gear. By pressing the clutch peddle a couple of times it becomes operational again and I get the use of the gears back.
The sound is comming from the footwell/ peddle- has anyone experienced this and can let me know how to solve it.
Cheers
Steve
sm0129
Postby gemini » Tue May 16, 2006 11:36 pm
its the adjustment ratchet on the pedal needs replacing
one here
http://cgi.ebay.co.uk/Ford-Transit-Van- ... dZViewItem
gemini
Postby motorwise » Tue May 16, 2006 11:40 pm
gemini wrote:its the adjustment ratchet on the pedal needs replacing
sounds about right - if it keeps giving trouble ford do the bits to convert to manually adjustable cable
http://www.motorwise.net
motorwise
Postby stevo » Wed May 31, 2006 8:12 pm
I drove 60-70 miles to Northampton from Birmingham today, when i got there, i put the clutch, made a crackinig noise, couldnt find a gear for love nor money. Ended up stuck on an island, got it working in the end, worked all the way back home too. Bloody thing.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
