by bazw » Fri Jan 29, 2010 1:56 pm
if i can harp back what kind of cold start system does it have ? electric with a feed from the diesel cut off going to the pump and then a wire to a switch on the block , or is it water activated with a pull wire running up to the thermostat housing ?
i ask because when mine used to do this with a 70 ps engine it was the cold start doing it , started up ok but lumpy as hell for a couple of min , sfter that it was fine all day and a retro fitted pull wire added by myself sorted it out from in the cab , only time i have had a really lumpy tick over after that was when i had a cracked head
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
