mk5 exhaust
mk5 exhaust
Postby geminivehicles » Tue Jan 26, 2010 8:21 pm
will a L reg 2.5 di exhaust fit a 1999 T reg mk5
thanks in advance paul
1999 100 MK5 LWB CUSTOM SHR aux batt,e/w,c/l,tv,dvd,xbox,cctv
transit mk5 custom with a evil twist (painted at last)
geminivehicles
Re: mk5 exhaust
Postby MrMPuk » Tue Jan 26, 2010 8:26 pm
There's about 8 different exhausts for a t reg.
Re: mk5 exhaust
Postby Jim Archer » Tue Jan 26, 2010 10:20 pm
No, not straight off, but a bit of judicious cutting and welding gets it somewhere near.
Make sure you hang it carefully and securely as it hasn't got the flexi section behind the gearbox - easily added, if a bit time consuming - and the clamp plate under the rear gearbox mount needs a bit of work to stop the manifold joint studs breaking. You'll most liely need to move some of the hanging hooks, but all the bolt holes are there.
Mines a right mixture of MK4 front pipe (got a fair bit bigger bore than any others I've seen) and 2 turbo silencers (straight through rather than baffled). I put a flexi section in between the flange and silencer box of 1st silencer.
HTH
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: mk5 exhaust
Postby GBBiker » Tue Jan 26, 2010 10:25 pm
Depends on whether SWB, LWB, rear exit or side exit.....
To all intents and purposes, on the 2.5 Di Banana NON TURBO engine, the front section up to the flexi joint & first silencer is the same regardless of the engine's BHP. It's the second box backwards that differs according to model year. Although there are some very early MK3 Di's that don't have a flexi joint.
There are several variations through MK3 - MK5 from second box backwards.
2 side exit options for chassis cabs / pick ups / tippers
2 rear exit options for SWB panel vans (year dependant, first option up to end 1996, second 1997 onwards)
2 rear exit options for LWB panel vans (year dependant, first option up to end 1996, second 1997 onwards)
The only differences in the SWB and LWB variants from what I have seen are the hanging brackets and the length of the crook over the rear axle. I guess you could fit an earlier rear section to a later van but don't quote me on it.
Other differences occur if you have the very basic 70ps non banana diesel, turbo diesel engines or petrol engines.
If we know the engines of the vans you refer to, it will be easier to tell you what will fit.
GBBiker
Wrong Again!
Re: mk5 exhaust
Postby geminivehicles » Tue Jan 26, 2010 10:31 pm
GBBiker wrote:Depends on whether SWB, LWB, rear exit or side exit.....
cheers the L reg is a 1994 2.5 di 80ps LWB and the T reg is a 1999 2.5 di 76ps lwb :D
geminivehicles
Re: mk5 exhaust
Postby kinty » Tue Jan 26, 2010 11:34 pm
im sure the 76 ps has a double pipe from manifold down,where as the 70 ps has a single pipe down to box....just that somone above said they are the same :?
kinty
Re: mk5 exhaust
Postby AndyG » Wed Jan 27, 2010 1:18 am
The banana engine uses both single (Ask Trigger) and twin (ask Nada) downpipes, depending on model and year :D
Re: mk5 exhaust
Postby GBBiker » Wed Jan 27, 2010 12:53 pm
kinty wrote:im sure the 76 ps has a double pipe from manifold down,where as the 70 ps has a single pipe down to box....just that somone above said they are the same :?
I did say the 70ps was different :wink:
Anyway back to the OP, which part of the exhaust do you want to fit?
GBBiker
Wrong Again!
Re: mk5 exhaust
Postby geminivehicles » Wed Jan 27, 2010 4:35 pm
middle and back
geminivehicles
Re: mk5 exhaust
Postby GBBiker » Wed Jan 27, 2010 6:21 pm
So basically the whole system apart from the 4-2-1 manifold then?
GBBiker
Wrong Again!
Re: mk5 exhaust
Postby geminivehicles » Wed Jan 27, 2010 6:22 pm
GBBiker wrote:So basically the whole system apart from the 4-2-1 manifold then?
yep
geminivehicles
Re: mk5 exhaust
Postby GBBiker » Wed Jan 27, 2010 11:27 pm
yep
Should fit then with a bit of modding to the hangers. You may need to lengthen or shorten the rear one depending on whether or not you have the same suspension (ie; high centre of gravity as opposed to standard)
GBBiker
Wrong Again!
Re: mk5 exhaust
Postby geminivehicles » Wed Jan 27, 2010 11:29 pm
yep
mine sits quite high
geminivehicles
Re: mk5 exhaust
Postby GBBiker » Wed Jan 27, 2010 11:32 pm
But does the donor? If it does it should be pretty much a straight swap. If not, you will need to fiddle with the hanger.
GBBiker
Wrong Again!
Re: mk5 exhaust
Postby geminivehicles » Wed Jan 27, 2010 11:35 pm
thanks to everone for there help more so gb biker :D
geminivehicles
