replaced fuel pump -thick white smog -can get higher rpms
Postby koondaholaa » Sat Feb 06, 2010 8:21 pm
hello
i have replaced the fuel pump recently with timming belt and had some issues starting it
i then towed it for about one minut with injectors cracked open then closed them and the van started
lots of very thick smoke and after while i got it to rev high but as the time went on its not possible to get her
to rev high . It starts and run in idle no prob .
i tried further bleeding of the injectors they are having a lots of pressure but no high idle and more and more smoke
kind of white and thick
i blacked out the egr valve and took of airfilter but runs exactly the same
can you please advice me on the cause and how one advance the timing on the fuel pump??
i read a post saying white smoke is sign of retardan timing ??
many thanks kamil
koondaholaa
Re: replaced fuel pump -thick white smog -can get higher rpms
Postby Backbone of Britain » Sat Feb 06, 2010 8:23 pm
Re-check your timing, sounds like its way out!!
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby koondaholaa » Sat Feb 06, 2010 11:25 pm
hello thanks for the answer
I have no idea about the timing of the fuel pump
i did the pins when i was putting on the timming belt
but i guess i didnt advance the pump right ??
can you please give me idea how this is done ??
do i have to take of the timing belt again ??
thanks kamil
koondaholaa
Postby psv-hgv-flt » Sun Feb 07, 2010 7:35 pm
koondaholaa wrote:hello thanks for the answer
thanks kamil
YES,
:wink:
psv-hgv-flt
Postby sydney » Wed Feb 10, 2010 12:40 pm
Your crankshaft is one full turn wrong-your motor is running on wet fuel on the piston tops
Fit timing pin to pump and cam -Remove timing belt- turn crank one full turn-( of course remove crank timing pin first !!)
You cannot turn the pump half turn (no holes) Likewise Cam-
Other words it is possible to accidentally turn the crank and have the pump injecting no4
instead of no1
sydney
Postby sydney » Wed Feb 10, 2010 12:46 pm
Further to above--turn crank VERY SLOWLY AND CAREFULLY IN CASE CAM IS IN AN INTERFERING POSITION- IF YOU DINK A VALVE YOU REALLY HAVE PROBLEMS
sydney
Postby sydney » Wed Feb 10, 2010 1:02 pm
Sorry-- Very late in OZ--IGNORE ABOVE AND INVESTIGATE POSSIBILITY PUMP IS INSTALLED ONE OR TWO OR THREE HOLES WRONG--prev comments commonly found in land cruiser and similar belt drive systems-- timing marks pump and crank are correct but 180 wrong with cam.
As ford ccam to crank timing on ford is fixed by pins your timing pulley must be wrong-
Carefull
sydney
Postby koondaholaa » Wed Feb 10, 2010 5:15 pm
thanks man
problem solved
it was the advancing of the fuel pump which was incorrect
see my new post about solution and thanks for your time kamil
koondaholaa
