mk5 transit 98 - loss of power up hills
Postby firestorm » Tue Feb 09, 2010 10:46 am
Just a quick thing, going up hills it seems to me like not enough diesel getting in it drops power but then picks up again.
been reading about etc and i'm guessing I should be doing this?
viewtopic.php?f=18&t=45777 - the Torque sleeve problem with the pumps?
firestorm
Re: mk5 transit 98 - loss of power up hills
Postby firestorm » Thu Feb 11, 2010 10:08 am
any ideas?
firestorm
Postby MinorMatt » Thu Feb 11, 2010 10:30 am
Torque sleeve feels like the van has a turbo, ie nothing until you hit about 3000 rpm and then it comes to life
Has your van had the leak off mod done? Which injector has the blanking nipple on it?
Postby Vee4 » Fri Feb 12, 2010 10:26 am
With my Mk5 (of fond memory), slowing down up hills was an endearing feature, not a fault.
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Postby matthew2riches » Fri Feb 12, 2010 11:07 am
Vee4 wrote:With my Mk5 (of fond memory), slowing down up hills was an endearing feature, not a fault.
I can second that :lol:
matthew2riches
Postby barabas » Fri Feb 12, 2010 11:11 am
When did you last change the fuel & air filter? Any smoke? Last major service (cambelt etc)? If all good, try turning the midrange up on the pump, worked a treat on mine for the hills - viewtopic.php?f=18&t=3968&p=27790&hilit=egr#p27790
The two most common elements in the universe are hydrogen and stupidity.
barabas
