Mk 5 Front Wings / Arches
Postby kermit » Sat Feb 13, 2010 5:12 pm
I have a Mk 5 transit which has had a replacement o/s front wing fitted, but now the wheel arch has started to rust away :roll:. Is it possible to replace the wheel arch with the wing still fitted or does it need to be removed first.
Kermit
1999 Mk5 190 8 seater, in British Racing Green - Rust In Peace - You have served us well. :cry:
kermit
Re: Mk 5 Front Wings / Arches
Postby rhurt5 » Sat Feb 13, 2010 5:17 pm
Hi,yes you can leave the wing on and either,grind out the rust and repair/fill and then repaint,of buy a replacement arch and fit as either a over arch or cut out the rotten one and stitch weld in the new one.I normally cut the worst out then lay on as a over panel,weld as required then fill to contour and repaint.
rhurt5
