i got this van to do the abit of body work on it and it ended up abit of a bigger job than 1st expected, new front wings, front wheel arches, new rear arches, new side loading door and alot of repairs!!!
good jobon that mate but the amount of times ive heard it just needs a bit of bodywork always makes me smile always turns into 3 or 4 times the amount of work you thought
i made the front inner and n/s/r inner arches from sheet metal dont look pritty but does the trick... but on the o/f/r arch i had an idear of buying 2 outter arches and using 1 as the iner as u can see in the pics line it up cut the rust out and bob your uncle looks alot better and fitts better and a lot less work
