by johny transit » Tue Feb 16, 2010 5:24 pm
Ok it is all done...and working!!!
I did manage to get the speedo needle off, it was very stiff indeed and I was concerned about ripping the whole spindle out but it went ok. After that I took out the rotary number unit (three screws on the back of circuit board) but I could not get them to move around at all - seems like they are all locked together internally to each other. So, I took the speedo gubbins off the old clock set (what I mean is the circuit board for the speedo, along with the mileage mechanism, the whole thing) and put that onto the new (smaller) speedo fascia panel. It all went back ok (except I got all the various screws all muddled up even though at the time it seemed perfectly clear) so now I have working rev counter and correct mileage. Only slight problem was that on starting, the speedo went to 20mph so I just took the needle off and with the engine running pushed it back on to 0mph, which was quite difficult to get right so I wouldn't mind checking that the speedo is exactly right so I don't go and get myself a load of tickets but otherwise it is a great job. I now have available the standard clock set for petrol tansit incase there are any takers!
It has to be said I couldn't have done it (indeed hadn't even heard of this mod) without the forum!
"There's always a way"
johny transit
