76ps Banana Upgrade Bosch Pump
Postby GBBiker » Tue Feb 16, 2010 7:16 pm
How simple is it to upgrade a 76ps Banana with Bosch pump?
Is it just a case of fitting a 145 or 146 pump and different injectors (ie; 100ps or 115ps)? Is it absolutely necessary to change the pump?
I presume the fuelling will have to be adjusted afterwards?
GBBiker
Wrong Again!
Re: 76ps Banana Upgrade Bosch Pump
Postby bazw » Tue Feb 16, 2010 7:28 pm
dont know if a pump and injector change would do anything as you need more air into it as well as more diesel , go on get a turbo , you know you want to :mrgreen:
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby slogger » Tue Feb 16, 2010 7:40 pm
Can you put a turbo onto a normal 2.5 di banana motor ? are there many things to change aside from the exhaust
slogger
Postby barabas » Tue Feb 16, 2010 7:42 pm
How about a supercharger? :lol: Plenty of grunt to drive it.. 8)
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby MinorMatt » Tue Feb 16, 2010 9:08 pm
My van had the bananna engine (and still does)
it now has a 145 pump with 33710 (brown spot 100PS) injectors with a turbo and turbo manifolds - its certainly a lot quicker!
You dont absolutely need the 145/146 you can use whatever pump you have, but if you put turbo injectors in without a turbo there is no way it will pass the mot smoke test
