SMILEY FACE STARTS UNEVENLY
Postby the gurns » Thu Feb 18, 2010 11:13 am
Hi guys,got a problem with our 96 smiley face,when its started from cold it doesn't run smooth for the first few secounds,as if a plug was breaking down (if it was petrol!) but its a 2.5 di so not that,its not as bad as it was (just had the cambelt changed) but it smokes for a few minutes after start up too,when its warm its fine all day. any thoughts??
the gurns
Re: SMILEY FACE STARTS UNEVENLY
Postby psv-hgv-flt » Thu Feb 18, 2010 11:20 am
check pump timing (advance it a bit), injector dodgy, air in fuel, and set valve timeing up and blank egr and tie strap open intake butter fly. (the rod from pump to inlet manifold)
:wink: ps thats a clean looker. 8)
psv-hgv-flt
Postby the gurns » Sat Feb 20, 2010 5:13 pm
Cheers mate will try that.
the gurns
Postby ZeldaTheWelder » Sat Feb 20, 2010 5:55 pm
My 96 semi high is doing the exact same thing be interested to see what the cure is. :? :D :D
I'm hopeing to respray my van up over summer and if it looks anythink like yours ill be well happy. :D
96 mk 4 smiley banana swb semi hi top
Mk6 swb low top with even more rust!
04 Connect T220 LWB.
ZeldaTheWelder
Postby richycarpets » Sun Feb 21, 2010 9:34 am
i had same problem i opend egr valve it solved it strayt away
richycarpets
Postby the gurns » Fri Feb 26, 2010 7:11 pm
Sorry to sound a real spanner but do I take the pipe off the little pipe? tie wrap the flap open and remove which rod?
the gurns
Postby Altransit » Fri Feb 26, 2010 7:25 pm
Postby the gurns » Fri Feb 26, 2010 7:27 pm
This forum just gets better and better,cheers guys every problem I have with my van I come here and its sorted. :wink:
the gurns
Postby the gurns » Sat Feb 27, 2010 10:01 am
I tied the egr valve open but haven't taken any of the small pipes off,I noticed that the intake pipe (the big one) onto the egr is split and perished (allowing air in?) I gaffer taped it up for now but will change it when I find out where to get one (main dealer?) The van seems to run better with the valve open and picks up better in the gears.
Any comments?
the gurns
Postby psv-hgv-flt » Sat Feb 27, 2010 10:19 am
the gurns wrote:I tied the egr valve open but haven't taken any of the small pipes off,I noticed that the intake pipe (the big one) onto the egr is split and perished (allowing air in?) I gaffer taped it up for now but will change it when I find out where to get one (main dealer?) The van seems to run better with the valve open and picks up better in the gears.
Any comments?
GOOD :D .in it the best when it cost's f***, just a tweek. :D :wink: i love these one's (tweek-tweek) :lol:
psv-hgv-flt
