creaking front suspension or shockers.
Postby vanfox » Thu Feb 18, 2010 1:55 pm
MOT time and the Mk 5 Smiley Di steering has started to creak. Had it on the jack, checked the bottom ball joints etc, the creak appears to emanate from the top half of the shocker, both sides. Hold the lower half and can't feel anything, hold the upper shroud and you can plainly feel the creak. Shockers don't appear to be leaking.
Any ideas?
vanfox
Re: creaking front suspension or shockers.
Postby GBBiker » Thu Feb 18, 2010 2:32 pm
May be worn shocks, may not be.
Have you checked the condition of the coil springs? Mine creaked on the N/S when turning. It was due to a fractured srping.
GBBiker
Wrong Again!
Postby psv-hgv-flt » Thu Feb 18, 2010 6:23 pm
tower bearing.
psv-hgv-flt
Postby darkbluevanman » Thu Feb 18, 2010 7:10 pm
Lift the rubber caps in the cab and spray a bit of WD or summat on 'em. prolly bearing as psv says, but if you lucky it may be sqeeky rubber?
darkbluevanman
Postby serpen » Wed Feb 24, 2010 7:28 pm
had the same problem with mine after doing the steering gaitor, attacked it with wd40, and seems to have quietend down. If it comes back, may just have to upgrade the cd player!
When this baby hits 88 miles per hour were gonna see some serious sh*t!!
1996 mk5 transit
Go the mighty Ex-Bt spec
serpen
