Got a Transit recovery truck. Giving it a refurb tring to make it last another load of years.
Its pretty much rust free. Seems to have had new arches and well protected all over.
On the rear where the window is you cant see the rust until you remove the window when i did that today i found out that the little lip that holds the seal in is rusty.
Its not that bad you cant see it when the rubber is on. But i need to sort it before i put the window back in whats the best way to do this ???
