96 tourneo 2.0 dohc engine swap????
Postby dodgy01 » Thu Feb 18, 2010 9:11 pm
i have a 96 tourneo with a 2.0 dohc 8v angine in it and i was thinking about a 2.5 di engine swap
other than the engine fuel tank , fuel pipes exhaust radiator .prop is there anything elsei would need to change like gearbox or rear axle
cheers
any one have a descent di going cheap
cheers
dodgy01
Re: 96 tourneo 2.0 dohc engine swap????
Postby captain hook » Thu Feb 18, 2010 9:31 pm
Yep....£200 8)
captain hook
Postby ostosix » Thu Feb 18, 2010 9:33 pm
Hi there,
I changed my '95 150 DOHC for a DI. Prop shaft is the same but gearbox is different. You also need the engine mounting brackets from a diesel, they are very different.
If I was doing it again I'd try and keep the radiator so it's got the electric fan on then you may be able to ditch the viscous fan which constantly runs and takes power.
Think of some sound proofing while the engine is out too as petrol has none but you do need some. You'll need a new exhaust down pipe too, only about 30 Quid though.
Power steering is on opposite side of the engine so you'll needthe diesel version. And the wiring of course. Air box from a diesel too. I got a rusty donor van for £280 quid. Got all my bits off Including engine and scrapped it and got £180 for that. The only mistake I made was scrapping the diesel gearbox, they look the same but the diesel bell housing is much bigger. A new one only cost me 30 quid though ha ha!
Sorry for this being a bit listy, I'm using my phone. Any question get in touch will be glad to help with any info.
Regards mikey
ostosix
Postby psv-hgv-flt » Thu Feb 18, 2010 9:41 pm
and front springs are stronger. :wink: keep the viscous fan. (that works)
psv-hgv-flt
Postby Maltesefalcon » Fri Feb 19, 2010 12:07 pm
Radiator is not the same. Pipe diameters are different and even the pipe positions are different. Gearbox is different and final drive for petrol normally is 5.14. If you are going to fit a turbo engine a 5.14 ratio is not good so you will need a 4.63 ratio. If you need more help let me know as I did this job twice here in Malta.
Maltesefalcon
Postby johny transit » Fri Feb 19, 2010 12:35 pm
Why on earth would you want to take out the rare, fast economical and quiet petrol engine and put an incredibly noisy and slow deisel engine in? For 5mpg more? I spent ages looking for a dohc'er and would have loved a Tourneo, just couldn't find one (in good nick). Well, that's my two peneth worth anyway :)
"There's always a way"
johny transit
johny transit
Postby dodgy01 » Sat Feb 20, 2010 7:52 pm
it is a bit rattly poss timing chain or just hydraulic tappets but the di are very reliable
if i could find a donor engine i would re build it then change it
i cant afford to take it off the road for a rebuild
dodgy01
