oil leak
oil leak
Postby trannyvan » Fri May 26, 2006 7:27 pm
hello could anyone help me
i have a transit 2.5 di swb semi hi on an x plate with 44k on the clock and i have got an oil leak. please excuse me as ill try to explain it the best i can. as your looking at the engine behind the airbox i can see some sort of gaurd around a pump, and it looks oily and is leaking down onto the exhaust, would it be engine oil or gearbox, any help would be ace.
thanks.
trannyvan
Postby crazyscoot » Fri May 26, 2006 8:33 pm
sounds like tha lift pump? if it is then it'll be engine oil
Negative reality inversion
crazyscoot
Postby AndyG » Fri May 26, 2006 8:42 pm
Don't think gearbox oil :?
Do as crazyscoot says and also check your rocker cover gasket at the back :idea: with a cold engine have a careful look using a good torch and a mirror :!:
Either way it doesn't sound major :D
And by the way; WELCOME :D
Postby madmark » Sat May 27, 2006 4:12 am
:shock: it will be rocker cover gasket or the lift pump O ring! :wink:
Postby trannyvan » Sun May 28, 2006 6:38 pm
ok thanks guys thats put my mind to rest ill check it out. :D
trannyvan
Postby Transitwalla » Sun May 28, 2006 7:23 pm
trannyvan wrote:ok thanks guys thats put my mind to rest ill check it out. :D
Look at it by all means and judge the severity of the leak...if its only weeping a little . . leave it :shock: and top up regularly with quality engine oil :) ....this has the added benfit of not only feeding the engine fresh new oil regularly :) but puts you under the bonnet and in position to spot anything going wrong before it gets serious :D . . also as gravity pulls the leaking oil downwards the underside of the van gets a coating - albeit on one side :( - which on a Transit can't be a bad thing can it???
The downside is ..... the oils drips on the drive :evil:
Welcome, BTW, and enjoy.
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Postby Luke » Sun May 28, 2006 8:03 pm
Teamster wrote:Look at it by all means and judge the severity of the leak...if its only weeping a little . . leave it :shock: and top up regularly with quality engine oil :) ....this has the added benfit of not only feeding the engine fresh new oil regularly :) but puts you under the bonnet and in position to spot anything going wrong before it gets serious :D . . also as gravity pulls the leaking oil downwards the underside of the van gets a coating - albeit on one side :( - which on a Transit can't be a bad thing can it???
couldnt agree more :D A leaky engine = healthy chassis :wink: :lol:
Postby OxtonyxO » Sun May 28, 2006 8:09 pm
my chassis should be rebuilding its self then the amount of only under it rear crank oilseal gone :lol: :lol: :lol:
still not long till 24v power :!:
OxtonyxO
Postby Nighthawk » Sun May 28, 2006 9:07 pm
Luke wrote:leaky engine = healthy chassis :wink: :lol:
And lots of scared bikers
Oil leaks add danger to the roads, get it sorted as soon as you can.
Transit.........Job done
Nighthawk
Postby MrMPuk » Sun May 28, 2006 9:11 pm
Luke's a biker but i'm not, I just leave them in my wake!
Postby Luke » Sun May 28, 2006 9:12 pm
as a biker im more worried about diesel leaks :lol:
Postby 100ps_drw_hicube » Sun May 28, 2006 9:15 pm
as a drifter derv on the road is a night mare bloody busses :x :evil: :evil: :evil:
100ps_drw_hicube
Transit Abuser!!
Postby trannyvan » Sun May 28, 2006 9:46 pm
wow thanks for the response, i only found this link by accident and im glad i did. as for the underside it should be ok i bought the van when it was 18 monts old with 17k on it and the first thing i did was clean the underside of the whole van and undersealed it so hopefully it should be ok.
trannyvan
Postby Transitwalla » Mon May 29, 2006 11:20 am
Born again biker myself :) the amount of oil that would weep from a leaking rockerbox gasket is negligible....would probably burn on the exhaust before it hit the ground anyway.
There'sno reason for diesel to be on the road unless theres been an accident...those guilty of spilling diesel on the public highway :evil: should have a finger amputated :) to serve as a constant reminder of the potential carnage that can be caused by carelessness.
:evil: :evil: Several times, in the last 24 years, I've seen bikers come to grief on diesel spilt by careless drivers leaving fuel caps off and roadwork gangs filling the powered rollers used to lay Tarmac :evil: :evil:
Also there seems to be a worrying trend by the utility companies, and others, to dig up the road and place a manhole cover in the middle of a corner or use excess amounts of tar overbanding - both absolutely leathal in wet weather - when finishing up.
Jim.
Transitwalla
Postby motorwise » Mon May 29, 2006 11:39 am
put a rocker cover gasket on it - wash it off - no more black dots on drive :D
http://www.motorwise.net
motorwise
