Full winter tyres in the summer
Postby RyanJJones » Mon Feb 22, 2010 8:30 pm
My tyres are due for a change (31,000m!)
But next winter I'll be spending a lot of time in the Alps - and thus want full snow tyres.
Only likely going to do 4-5000 miles before then, so don't want to replace with summer tyres then bin them to get winter.
Are full winter S+M tyres okay in dry/summer as well?
Eyeing up Continental VancoWinter 2 195/70 R15 97T RF
RyanJJones
Re: Full winter tyres in the summer
Postby matthew2riches » Mon Feb 22, 2010 8:52 pm
My guess is that they'll wear down very quickly and they'll be very noisy on the road... :wink:
matthew2riches
Postby BigNeil » Mon Feb 22, 2010 8:54 pm
on my road car it wears M+S tyres all the timeyes you get road noise but they last about the same time.
I would however say get some real cheap tyres on until you want to got hen the m+s tyres will be fresh fro going and give you maximum grip, you may also consider chains
BigNeil
Postby RyanJJones » Mon Feb 22, 2010 9:12 pm
Hi.
I have (and use!) chains on last time we took the van away.
Main issue is its jsut about on 2,8T limit (campervan) and FWD - so as soon as ice comes the front end grip is shite.
Road noise isn't a huge concern - we don't drive it that quick, and as it has a high top glued on with skylights etc it isn't the quietest thing.
Even cheap tyres is quite a cost - so if the S+M don't wear quicker then thats a good 'un
TVM
RyanJJones
Postby GBBiker » Tue Feb 23, 2010 11:07 am
Could you not just pick up another set of steel wheels and have the snow tyres fitted to them? Just use budget commercial tyres on the van in the mean time and swap them over when you need to? Saves binning a decent set of tyres.
GBBiker
Wrong Again!
Postby bazw » Tue Feb 23, 2010 2:47 pm
my local part worn tyre place does tyres for my van @ £15 a corner , normally good for a year or three as i do low mileage
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Timbo » Tue Feb 23, 2010 8:32 pm
Interested in those!!!!!! Where do you get them - Anne Summers ???
Timbo
Postby Frag » Tue Feb 23, 2010 8:37 pm
Timbo wrote:Are full winter S+M tyres okay in dry/summer as well?
More adventurous drivers shop there,looks like "normal" folk get theirs at Marks & Spencer :lol:
Frag
Ford Technician
Postby ZeldaTheWelder » Tue Feb 23, 2010 10:35 pm
GBBiker wrote:Could you not just pick up another set of steel wheels and have the snow tyres fitted to them? Just use budget commercial tyres on the van in the mean time and swap them over when you need to? Saves binning a decent set of tyres.
or keep a eye out on ebay like me i just got a set of 4 wheels and tyres with average of 7mm
tred for £40.50 :D :D
well chuffed as got MOT in april and my current one getting very low.
96 mk 4 smiley banana swb semi hi top
Mk6 swb low top with even more rust!
04 Connect T220 LWB.
ZeldaTheWelder
Postby MinorMatt » Tue Feb 23, 2010 10:38 pm
or you could be a lucky bugger like me, I got a set of full winter tyres in the middle of the snow this year for my escort for £18. 7mm left on the fronts and 5 on the rears!
