Alternator ... Which one?
Postby StuartB58 » Tue Feb 23, 2010 12:41 pm
I'm having a problem with the charging system. The ignition light flickers when running not just tick over. Would it be ok to fit a 95amp alternator, the van does have twin batteries fitted. (Mk5 2.5td automatic)
Thanks in advance,
Stu.
p.s. belt tension ok.
MK6 Twin wheel 2.4 in white
Ford where rust is NOT an option.
StuartB58
Re: Alternator ... Which one?
Postby GBBiker » Tue Feb 23, 2010 1:11 pm
Yes it will be fine. The batteries won't be affected by the capacity of the alternator.
GBBiker
Wrong Again!
Postby StuartB58 » Tue Feb 23, 2010 1:14 pm
Thanks for the help. :)
Stu.
StuartB58
Postby psv-hgv-flt » Tue Feb 23, 2010 4:30 pm
StuartB58 wrote:I'm having a problem with the charging system. The ignition light flickers when running not just tick over. Would it be ok to fit a 95amp alternator, the van does have twin batteries fitted. (Mk5 2.5td automatic)
Thanks in advance,
Stu.
yes no probs, and if it is 97 on then it should allready be 95amp, just need to alter connectors
psv-hgv-flt
