how do you wire up an external cold start
Postby white transit man » Tue Feb 23, 2010 8:53 pm
hello ive got a 98 transit with an earlier engine in it (ive been told ??) it has a cold start that looks like a sausage with a wire going through it. i know nothing about engines thus why im on here. i need to know how to wire it up to test that it works if not ill get another one. there is one wire coming off the back of the cold start and i dont know where it goes or what other wires need to go where (if any) if any body can help can you please explain it as if you are explaining it to a ten year old thanks :?
white transit man
Re: how do you wire up an external cold start
Postby MinorMatt » Tue Feb 23, 2010 9:54 pm
Personally I woul just attach a choke cable to the little lever coming out of the side of the injectio pump that the wire from the sausagey thing goes to
Postby white transit man » Tue Feb 23, 2010 10:03 pm
thanks frag ive already seen those posts ive been looking on here for ages, i need a stupid persons step by step guide and explaining what thing look like and where wirs go to thanks mate,
minormatt ive thought about this option, how would i get the cable throuth to the dash, whats the best position to come from the engine, would i have to drill a hole through from the engine side??? thanks...
white transit man
Postby Frag » Tue Feb 23, 2010 10:11 pm
Don`t think the choke cable idea would work ? there`s a hell of a lot of tension on the lever :shock:
Just try pushing it back !
When engine is running pump pushes against it,you can feel mechanism in pump pulsing.
If you let too much tension off lever or let it release too far,van runs crap & white smokes as the lever affects pump timing.
Best to fix original system,when working they are a great set-up :)
Frag
Ford Technician
Postby MinorMatt » Tue Feb 23, 2010 10:20 pm
fair enough :)
Postby white transit man » Tue Feb 23, 2010 10:23 pm
thanks anyway minor matt :D
white transit man
Postby white transit man » Tue Feb 23, 2010 10:28 pm
ok frag thanks............... so where does the wire from the cold start go to (its got a spade connector on the wire)? and what powers it ?... remember you are talking to someone who knows little about engines
white transit man
