leaf spring mot failure
Postby stuartwilkins1 » Wed Feb 24, 2010 4:53 pm
had an mot failure on `nearside rear leaf spring longtitudinally displaced`.
Does this mean its knackered ?
If yes is it an easy bolt off bolt on change and are they standard parts ?
Anyone got one or know of a supplier round Birmingham way ?
Thanks in advance.
[color=#0000BF]Wilkinstall Plumbing & Home Improvements-West Midlands Stuart 07708731610.[/color]
stuartwilkins1
Re: leaf spring mot failure
Postby GBBiker » Wed Feb 24, 2010 5:06 pm
Longitudinally displaced?
Sounds like it's come out of it's shackle, or one of the shackles has broken. Maybe due to the rubber perishing.
GBBiker
Wrong Again!
Postby bodgit0_0 » Wed Feb 24, 2010 9:46 pm
Take a look at the spring, I think it means that some of the leafs are rotating out of alignment.
If they have they should just be re-aligned, did this to a spring with a sledge hammer last time. Be warned it may need every thing loosening off first.
Current Fleet.
81 Metro 'S'
82 Metro HLE
85 Metro MG Turbo
86 Maestro MG Turbo conversion
89 Maestro MG Turbo '#370'
90 Maestro MG
90 Montego MG Turbo Conversion
88 Montego MG Estate 'F700'
94 Transit 4x4 Donor
99 Transit 4x4 LWB
bodgit0_0
Postby Wildy » Wed Feb 24, 2010 10:43 pm
Loosen shackle bolts, then hammer all the leaves into line. Then retighten up shackle bolts. Job done.
Some people are like slinkies, not really good for anything
but they bring a smile to your face when pushed down the stairs.
Wildy
