new rear shoes question
Postby stuartwilkins1 » Thu Feb 25, 2010 8:32 pm
Just replaced the rear shoes on my s reg transit and now they are spongey when running. Do they need bleeding again and do I need to manually adjust the ratchet system or does this set itself ? Thanks.
[color=#0000BF]Wilkinstall Plumbing & Home Improvements-West Midlands Stuart 07708731610.[/color]
stuartwilkins1
Re: new rear shoes question
Postby AndyG » Thu Feb 25, 2010 11:53 pm
Probably need bedding in :idea:
Is the pedal still spongy with the handbrake applied :?:
They're supposed to be self adjusting, but I've found that most need to be "clicked out" so the drum can just about go on :wink:
Postby stuartwilkins1 » Mon Mar 01, 2010 1:38 pm
the brakes are solid when the handbrake is on or when they have been pumped but with the engine running the pressure is lost. Going to try adjusting the ratchet now.
stuartwilkins1
