towing syndrone
towing syndrone
Postby H_munch » Fri Feb 26, 2010 10:52 pm
Just read the thread on towing with the 190 can you advise me , i need to pick up a chasssis cab 3500 250 miles away can i tow on a A frame ( strapping around the front wish bones ) useing a transit flairline rated 2700, the vehicle has no tax or mot and has no body attached is it legal to tow tyres good and lights work.if the vehicle is overweight the only way i can see to get the weight down would be to put the engine and box on the back of the truck and take 2 of the wheels of the back or does any one on the forum transport from A1 north to london, apreciate . cheers H.
H_munch
Re: towing syndrone
Postby Luke » Fri Feb 26, 2010 10:54 pm
is the A-frame braked or unbraked :?:
Re: towing syndrone
Postby transitbus1971 » Sat Feb 27, 2010 12:02 am
in the eyes of the law(vosa) the vehicle your towing with an aframe needs to be taxed, moted, insured. the frame can only be used for brokendown vehicle , not transporting a vehicle ! if the vehicle has no tax and mot it has to have all four wheels off the ground (tralier) , i now this as i drive a two car transporter for a living and i had a few run ins with vosa , they can also take you vehicle off you :(
transit bus 150 lwb
transitbus1971
Re: towing syndrone
Postby Luke » Sat Feb 27, 2010 12:05 am
transitbus1971 wrote:in the eyes of the law(vosa) the vehicle your towing with an aframe needs to be taxed, moted, insured. the frame can only be used for brokendown vehicle , not transporting a vehicle ! if the vehicle has no tax and mot it has to have all four wheels off the ground (tralier) , i now this as i drive a two car transporter for a living and i had a few run ins with vosa , they can also take you vehicle off you :(
only if it's an unbraked A-frame tho :D
Re: towing syndrone
Postby H_munch » Sat Feb 27, 2010 9:43 am
Apreciate youre imput i do have a braked A frame that i can use but it would seem a problem with VOSA with no tax or mot if i got stopped , if i used atrailer would that bring me over weight ? if i cant find some one reasonable priced to transport irll have to break it on the spot and cart it back on the truck , just a lot of work for nothing.do apreciate youre help cheers ,H.
H_munch
Re: towing syndrone
Postby transitbus1971 » Sat Feb 27, 2010 11:24 am
the only way to tow the vehicle back on a trailor is with a landrover / discovery as you would be over weight towing with your transit , with vosa its not easy as they work weights out differnt to what your van will say on its vin plate , if you go on there site it does sort of explain it . hope this helps
transit bus 150 lwb
transitbus1971
Re: towing syndrone
Postby Luke » Sat Feb 27, 2010 1:30 pm
if you have a braked a-frame you are fine the whole vehicle/a-frame combo is classed as a braked trailer and will be under your 2 tonnes limit :D
have a read of this :arrow: viewtopic.php?f=14&t=44505&p=397476
i have a braked a frame and use it to tow transits with no tax test of insurance with my transit :D
Re: towing syndrone
Postby geminivehicles » Sat Feb 27, 2010 1:33 pm
H_munch wrote:Apreciate youre imput i do have a braked A frame that i can use but it would seem a problem with VOSA with no tax or mot if i got stopped , if i used atrailer would that bring me over weight ? if i cant find some one reasonable priced to transport irll have to break it on the spot and cart it back on the truck , just a lot of work for nothing.do apreciate youre help cheers ,H.
where do you want moving from and to ill try and sort a price out as i have a 7.5 ton tilt bed
1999 100 MK5 LWB CUSTOM SHR aux batt,e/w,c/l,tv,dvd,xbox,cctv
transit mk5 custom with a evil twist (painted at last)
geminivehicles
Re: towing syndrone
Postby H_munch » Mon Mar 01, 2010 10:57 pm
Thank you for all youre imput irll let you now how i get on thanks again.cheers ,H
H_munch
