Pump swap
Pump swap
Postby steveselvage » Sun Feb 28, 2010 11:06 am
If i change the epic pump for a bosch will i lose performance? I have been told that the van will drive as if there is no turbo, surely it wont make much difference as long as the bosch delivers enough fuel.
steveselvage
Re: Pump swap
Postby AndyG » Sun Feb 28, 2010 3:43 pm
From what I understand, fitting the correct Bosch pump should give you good results :D
