I have a 99 banana with 113k miles. I have had it since 43k miles and used it daily. It has never let me down and started immediatly every time. However I havent needed it recently and didn't tax it from november, but started it and run it up the drive every week or two.
The problem is: If I start it every day or two it will start imediatly, but if I leave it for two weeks then it will run the battery flat trying to start but won't fire up. If I then charge the battery for a couple of hours it will start straight way.
If I charge the battery first it still does the same thing.
I am presuming an air leak that allows the diesel to drain back to the tank then the first batteries worth of engine spinning is bleeding the system, but I can't see any leaks anywhere.
Any ideas as to what this is and how to track it down.
Cheers
