handbrake only works on one side
Postby stuartwilkins1 » Tue Mar 02, 2010 9:46 pm
van has just failed the re test as one side has an excellent handbrake but the other side has nothing. Any ideas why ? Its just had new brake shoes and everything else is good. The end of the handbrake cable was re connected, is there any way this could of come out ?
[color=#0000BF]Wilkinstall Plumbing & Home Improvements-West Midlands Stuart 07708731610.[/color]
stuartwilkins1
Re: handbrake only works on one side
Postby LRN » Tue Mar 02, 2010 10:22 pm
Did you fit a new rear section of the handbrake cable??
If not, most likely this is sticking one side ... thats the favourite cause .... replace it
LRN
Postby stuartwilkins1 » Wed Mar 03, 2010 12:14 am
is that the part from where it splits after the adjuster ? Can it be greased for now just to get it through as I suspect ill have to order it.
stuartwilkins1
