Mark 5 electrical problem
Postby royspeed » Thu Mar 04, 2010 5:34 pm
I have found an unusual problem with the lights on my old heap of a Luton.
Every time I depress the brake pedal, the headlights come on!
I have checked the fuses, all seem OK, it came on almost overnight, after I did a run up to Milton Keynes from London, the problem appeared that evening.
I wouldn't mind, but there seems to be a drain on the battery as well, I regularly have to jump start the thing!
It is a 1994 Mk 5, BTW.
Any suggestions, apart from weighing it in?
Roy.
Royspeed - Transport/Removals
Only Transits used!
royspeed
Re: Mark 5 electrical problem
Postby the_big_fact_hunt » Thu Mar 04, 2010 6:52 pm
sounds like a short somewhere, check the wires around the pedal, column and bulkhead for a start
Solve the World food problem.......... Feed the homeless to the hungry
2012 115T350
the_big_fact_hunt
Postby AndyG » Thu Mar 04, 2010 10:31 pm
Sounds like 2 different faults :!:
You have a poor earthing on one of your rear lamps :!:
This causes the brake lights to earth via the sidelights :!: The headlamps also glow because your van has the "dim dip" feature where the headlamps come on when the side lights are on and ign./engine is also on :)
The battery draining is likely to be a separate fault :!: Either a faulty alternator diode pack or radio staying on :?:
To be sure, you'll need to use a test meter to determine what circuit is actually draing the battery :idea: Then deal with it :D
Postby GBBiker » Fri Mar 05, 2010 2:30 pm
Not quite on topic but 1994 will be a MK4 surely :?
GBBiker
Wrong Again!
Postby MinorMatt » Fri Mar 05, 2010 2:59 pm
Mk5 came out in M reg... so it is possible to have a late 94 smiley
Postby the_big_fact_hunt » Fri Mar 05, 2010 10:26 pm
tis true, i had an m reg mk5, it was my first transit
2012 115T350
the_big_fact_hunt
Postby AndyG » Fri Mar 05, 2010 10:30 pm
It's definitely a MK5 :!:
I know, as I've worked on it :wink: (or under it, if I remember right :lol: )
Postby spikefreeway » Fri Mar 05, 2010 10:45 pm
Andyg wrote:Sounds like 2 different faults :!:
Its likley that if you take the rear lense cluster off and clean the terminals and connectors a bob a bit of WD40 through it, that should bottom it. Its a feature of all Fords of a certain age.
The way best way to test the diode is as above, however a low tec solutiion is if you take the chunky red lead off the alternator (hopefully a sockety thing but possibly just the bolt on type) overnight and if it doesnt go flat then your diode has had it. Either replace the alternator or fit an isolater/breaker but remember to turn it back on again when you have started up!
HACK QUOD SLASH INSQUEQUO VOS ANIMADVERTO DIES LUX LUCIS (stolen!)
spikefreeway
Postby royspeed » Sun Mar 07, 2010 2:36 pm
Well, I have found the problem!
The cable carrying the wires to the rear light cluster were hanging down in front of the exhaust pipe, and it has fried the wires!
I will have to cut out the burnt section and reconnect it up, then tie the wiring loom up with ty-wraps to stop it happening again.
I think the wires were left loose when I got a new box on the back a couple of years ago, I just didn't notice it at the time.
Oh well, back under the van again!
I still need to get a new tail-lift motor, as the existing one is knackered, but they are so expensive!
Roy.
Only Transits used!
royspeed
Postby spikefreeway » Sun Mar 07, 2010 6:50 pm
yup that would certainly do it, glad youve got it sorted. :D
spikefreeway
Postby GBBiker » Sun Mar 07, 2010 7:01 pm
Andyg wrote:It's definitely a MK5 :!:
So it's not a MK4 Luton in his sig then? :? I can't see it properly, it's too small :oops:
GBBiker
Wrong Again!
Postby royspeed » Sun Mar 07, 2010 8:56 pm
Just for reference, here is the offending wire;
A bit knackered, wouldn't you say?
Roy.
EDIT; to GBBiker, It is definitely a Mk 5 in the signature, I have had a new box put on it since the picture was taken, due to a slight disagreement with a low arch! :oops:
Only Transits used!
royspeed
Postby captain hook » Mon Mar 08, 2010 1:56 pm
Do you still need a Tailift pump :?: :wink:
captain hook
Postby royspeed » Mon Mar 08, 2010 4:15 pm
captain hook wrote:Do you still need a Tailift pump :?: :wink:
I think there is a loose connection inside the tail-lift motor, it makes a horrible noise, and often refuses to work. I can hear the solenoid working, but I usually have to kick the box to get it to co-operate :!:
It is a Ratcliff column lift, TBH it was ropey when I got the new box fitted, but it has got gradually worse over time.
Can you point me in the direction of a better one then :?:
Roy.
Only Transits used!
royspeed
Postby vanfox » Mon Mar 08, 2010 7:03 pm
I could be wrong here but isn't the motor a modified starter motor? It's a long time since I drove small commercials but I seem to recall seeing the hydraulic pump bolted to ..... a starter motor. If so try checking the brushes, that may be all you need.
vanfox
