spaffmonkey wrote:It could just be the heater thermostat needs replacing
GBBiker wrote:spaffmonkey wrote:It could just be the heater thermostat needs replacing
Could be. A tell tale sign is the temperature gauge on the dash. Does it get up past the 'N' of Normal? If not, change the stat.
If this doesn't work, or isn't obviously the problem, it could be an airlock in the system. I would drain and refill the cooling system.
They are the cheaper options. No point spending hundreds on a new matrix if that isn't the problem
madbri wrote:might sound dafthow old is ure enginge oil
i changed my oil cause it had done 15,000 miles
and my heater was crap crap crap. now the kids tell me to turn it off to fucin hot
just a thought
spikefreeway wrote:GBBiker wrote:spaffmonkey wrote:It could just be the heater thermostat needs replacing
no it doesnt get past "N" but I figured this was normal as I had a Vauxhall Trooper rip off that didn't and a Mondeo on a "P" plate that didn't get much warmer.
Where should I be looking or is the answer to that in the Haynes manual! ta for that
