Fuel filter stuck
Fuel filter stuck
Postby Xbttran » Fri Mar 05, 2010 9:51 pm
Hi,
I need to change the fuel filter on my V reg transit 120. There is a large knurled plastic ring at the top of the filter which I assume you rotate in the direction of the - arrow and pull it off.
Only thing is the ring is jammed rock solid tight!!!
Has anyone on the forum had any experience of this problem and any ideas on how to solve it? Would a chain wrench do it?
Help before I resort to a hammer and chisel and ruin my van.
John
Xbttran
Re: Fuel filter stuck
Postby Standa » Sat Apr 03, 2010 10:46 pm
Well im stuck this way too. Any ideas how to remove that ring?
Standa
Postby Backbone of Britain » Sat Apr 03, 2010 10:53 pm
Twist it clockwise to undo. It should come off easily. If it is jammed solid then the filter was not installed correctly in the first place. Try pushing the filter upwards whilst unscrewing the retaining ring.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
