my turbo engine leaks oil like a hospital drip so i thought id bolt on the turbo and inlet manifold and i heard in a serch my 100psi injectors would be better but what about the loom inside the cab would i be ok if i just changed the engine loom?
im handy with a spanner but dont fancy changing just the pump
so basically need a bit of a guide to what i need to keep and what to bin
thanks
