Where can I get a G4X 2A, A127-70 Alternator.
Postby AndrewW » Fri Mar 12, 2010 5:33 pm
My alternator's on the blink and I need a reconditioned one. Alternatively I need to know if the original could be reconditioned. I've done the usual searches and drawn a blank. I live in Wolverhampton. Any recommendations would be much appreciated.
AndrewW
Re: Where can I get a G4X 2A, A127-70 Alternator.
Postby MinorMatt » Fri Mar 12, 2010 8:12 pm
Any motor factor, A127s were fitted to transits up to '97
Postby sidspop » Fri Mar 12, 2010 8:51 pm
Try Phil at Glaze Autoparts. Cable Street off the Bilston Road.
Tell em Andy the Thames sent you.
01902 455434
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby AndrewW » Sat Mar 13, 2010 10:22 am
Thanks for the posts. I'll let you know how I get on.
AndrewW
Postby sidspop » Sat Mar 13, 2010 10:39 am
Sorry, they are in Dixon Street, not Cable Street.
sidspop
Postby psv-hgv-flt » Sat Mar 13, 2010 10:56 am
i got one, but you would be best to put the 95amp on from 97-on.
psv-hgv-flt
Postby AndrewW » Sat Mar 13, 2010 1:40 pm
Thanks psv. It seems a good idea to get a 95 amp as it's for a camper with leisure batteries. Would there be any problem fitting this later model?
AndrewW
Postby MinorMatt » Sat Mar 13, 2010 1:59 pm
you would need the 2 pin plug and modify your wiring a little bit (but nothing too major)
Postby psv-hgv-flt » Sat Mar 13, 2010 7:38 pm
same fitting, just minor wire adjustment. (easy)
psv-hgv-flt
Postby MinorMatt » Sat Mar 13, 2010 8:12 pm
err no its not...
The bosch 95A has a 2 wire multiplug for the rev counter and exciter wire and a bolted on charge wire.
The lucas either has the wires all bolted on, or the earliest ones had a plug witch is basically boggo spade connectors.
Oops see what you mean PSV :oops: bosch one will bolt straight up
Postby AndrewW » Sun Mar 14, 2010 1:41 pm
Come Monday if the fittings don't overcomplicate things, I'll be looking for the higher watt version. I thought I'd give the Transit Centre in Dudley a call amongst others. Just out of interest does this place have a good reputation? Many thanks to the respondents for their help. This has been my 1st post and I am impressed by the readiness of others to assist.
AndrewW
