Chance of a new chasis...but will my engine fit???
Postby Mango76 » Thu Mar 18, 2010 6:23 pm
Hey guys!!
I have a 99 T reg 2.5 rear wheel drive transit (with only 80k miles on it), but last summer someone kindly hit the side of it and literally ripped a huge hole in it!! plus as on most transits my back doors are starting to disintergrate!!
I have just been offered a non running 2000 Y reg transit which currently has a 2.4 rear wheel drive engine.
My question is...would my engine fit into the new chasis??? i have been told that the wiring looms may be different but apparently i can get around that!! but will the engine mounts etc be in the correct places to take my 99 engine???
Thanks in advance guys
Mango
Mango76
Re: Chance of a new chasis...but will my engine fit???
Postby Altransit » Fri Mar 19, 2010 5:54 pm
I don't think anyone has actually done this, although it has been talked about :roll:
I can't see any reason why it wouldn't fit, but I doubt it will match up with the mounts without some fabrication, and the wiring looms would have to be swapped as well :wink:
Let us know if you do it :D
Postby Luke » Fri Mar 19, 2010 6:37 pm
it has been done - there was a mk6 Di on ebay :D
as for the wiring unless yours is a turbo theres not much to it :D but fabricating the engine mounts etc. might take a bit of work :D
like al says keep us informed if you do go for it 8)
