Tow In Tow Out Mk5 - also has anyone TIS Transit Code
Postby ob1cnoby » Fri Mar 19, 2010 12:45 am
Hi just tweeking my tracking, as there was very fast wear on the new set of tyres I have put on ( inside) I did the string line thing back to front, and found it was miles out (towd out about 1.5cm) and so now have put it close to straight through but feels a bit 'sqishy' on the steering, but I seem to remember on my TIS Tranny Disc, that it should be about 0.5 to1cm towed in, but went to check my disc, and couldnt use it, as i have recently had a virus on my pc, and had everything wiped off, and when i bought the disc, (ebay of course) I was sent a code to activate the disc- which is also now wiped, and cant remember the guy i bought it from. If its not an easy fix, I shall just buy another, but if someone knows an easy way to re-activate my cd, i would appreciate it
Thanks Dave
ps retuned my engine, and its running very strong now with no smoke
ob1cnoby
Re: Tow In Tow Out Mk5 - also has anyone TIS Transit Code
Postby Altransit » Fri Mar 19, 2010 9:57 am
As a rule of thumb, a RWD vehicle should have "Toe In" and a FWD should have "Toe Out" and it's never very much.
A vehicle with too much toe-in will wear the outside of the tyres, whereas too much toe-out will wear the insides :wink:
Postby ob1cnoby » Sat Mar 20, 2010 1:04 am
Yep Thanks Al, its about waht I guessed, soemone has put all new sterring arms/joints etc in, and forgot to make adjustments- think i will give it about 5-10mm toe in over the weekend- did notice also, that the rear wheel train is a bit out too, just about to start a mobile home conversion
ob1cnoby
Postby Frag » Sat Mar 20, 2010 6:34 pm
Wheel Alignment (at kerb weight) – Toe Setting
All Variants
Allowable tolerance before resetting is required 2,0 mm Toe in to ‐2,0 mm Toe out
Setting adjustment, if required 0,0 mm ±1,0 mm
Frag
Ford Technician
Postby ob1cnoby » Sun Mar 21, 2010 12:42 am
Hi Frag- are you sure about the tolerence's, as 1mm is about the thickness of a credit card- and would be barley noticable-even thin string is about 2mm thick, cant see it being that- but dont mind being put right, as i have this dead in line straight at the moment, it should be ok- I should have thought 2-3mm more like it, might google it, got to be something out there- cheers dave
ob1cnoby
Postby Altransit » Sun Mar 21, 2010 12:54 am
You can be sure that anything Frag says is spot on, as he's a Ford technician. :D
Postby Frag » Sun Mar 21, 2010 7:03 pm
Altransit wrote:You can be sure that anything Frag says is spot on, as he's a Ford technician. :D
Thanks :D ,the info was copy & paste straight from e-tis so should be right :wink:
Frag
Ford Technician
