Will mk6 transit wheels fit a mk5
Postby slogger » Fri Mar 19, 2010 3:58 am
Will mk6 transit steel wheels 16" fit a mk5 transit single wheeler 190 ? , mk6 is a similar van shape ie single wheel and both are 5 studs
slogger
Re: Will mk6 transit wheels fit a mk5
Postby Luke » Fri Mar 19, 2010 9:35 am
not really :) they are the same pcd but the studs are different and how they centre on the hub is different - the mk5 uses the nut taper and the mk6 uses the hub centre and the nuts purley hold the wheel back :D
can be done but to be safe you need to over come these issues :D
Postby slogger » Fri Mar 19, 2010 2:27 pm
Ok thanks for that , i had the chance of 3 new 16 " tyres and one rim , i will put them up for sale instead for the lad
slogger
