by shortcut » Sat Mar 20, 2010 8:02 pm
I've had to do just that in the past, if you have the complete section of replacement pipe with the nuts trapped on its length which lets face it, its not much use if it doesnt , then go for broke with a hacksaw. the bit your trying to save is the load valve and not the nuts !
Heat has been suggested which is always good and then whilst the nuts are hot a good dose of easing oil, but try not to heat the load valve as it may not do the internals any favours.
A small set of stillsons can be a blessing or a good pair of last resort grips can work wonders in these situations.
