This van has been nothing but the bane of my existance since buying it hahahah,replacement engine,egr valve,3 dam epic pump/systems as it just would never set up correctly.
The latest one seemed to work ok and at least emissions were good 2 get it through mot,but i still have the limp home mode problem,
i no longer need the van and am thinking of selling it,but i cant sell it the way it is (can i??? heheheh)
The van is ok on starting,once the engine starts to warm up and i let the revs off the engine lamp comes on and it goes into limp home mode,i can bypass this by quickly turning power off and restarting engine,that solves it in the short term (have been doing this the past year or so) but need to get it fixed once and for all,i have rang a diesel specialist who work with epic systems to ask if it could be turned off and they said it cant,
ive read lots into it and it could be a whole range of things that r out of sync and causing it to happen from slight fluctuations in power to what ive read with throttle position sensors and so on,on this forum,im thinking it gonna end up costing a fortune to get this problem properly diagnosed and corrected,just to be able 2 sell the dam thing,it wouldnt be fair to sell it without warning the person,but if i did then obviously they aint gonna be interested in buying it,so have little choice but to sort the problem.
I dont know if to get the cambelt changed,i read on here that accounts for 60% of the problems with limp home mode,it was done when the engine was replaced around dec 08/jan 09,although i must have only covered around 20k miles since then,i thought this would be the cheapest option first
Any further advice from you guys on what to do next,i did get codes read a fair while back but im told unless the original problem is sorted the codes cant be turned off and the problem remains.
Is it trial and error going through replacing part by part again until it works lol?
mk5 nothing even comes close
