Axle and hub help needed!!
Postby doughythevanman » Sat Mar 20, 2010 9:16 pm
Hi guys,
As you may remember i was asking about alloys for my mk5 smiley 6 stud. Minormatt thankfully infomed me the only way to go is to change the axle / hubs. :roll:
The question i have is... Do the later mk6 rwd axle and hubs fit and if not is there any modifying that can be done to make them fit? It's just that i have been told a rear axle/diff and front hubs from a 2.4 rwd are knocking about in a friends yard and was goin to try and get them off him.
Thanks for any advice!!! :wink:
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Re: Axle and hub help needed!!
Postby MinorMatt » Sat Mar 20, 2010 9:30 pm
I dont know about the front hubs, but I imagine it would be a whole world of pain! If you want mk6/7 alloys you can fit the mk5 front hubs and rear axle without any mods, but you will need to get the alloys countersunk.
However give your friend has a mk6 axle I would look at fitting that, take some careful measurements, if the spring hangers are the same distance apart then you are laughing. I would, however be looking for some mk4/5 hubs knock the wheel studs out drill out the holes and fit the M14 studs from the mk6 and counterbore the disc retaining bolt holes...
So in summary
rear axle - maybe, careful measurement required
front hubs - forget about it fit the mk4/5 5 stud hub and modify it slightly
Postby doughythevanman » Sat Mar 20, 2010 9:38 pm
Cheers matt!! :wink:
I wasnt too worried about using mk6 / 7 alloys really, it was just that i could get them very cheap! :lol: :lol:
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby MinorMatt » Sat Mar 20, 2010 9:41 pm
well if its a mate can you borrow them until you know if they will fit? :wink: (and then steal them :lol: )
Postby doughythevanman » Sat Mar 20, 2010 9:54 pm
(and then steal them :lol: ) :lol: :lol: are you psychic !!!!! :lol: :lol: apparently he has forgot they are at the yard so will try to convince him they were mine to start with!! :twisted: :lol:
Range Rover TD6
Volvo S80 D5
doughythevanman
