by jay » Sun Mar 21, 2010 11:22 pm
if the van has a mt75 box you are ok if its the old type box which is mainly mk3 then the heater box needs cutting as gearstick hits it....The bulkhead needs cutting as mk5 heater box pipes are higher up and a bit to the right you then blank off the hole left by the mk3/4 heater pipe...use the loom from the donar vehicle as its so much easier you can then fit a rev counter dash clock as well..done this to several transits over the years..
mk1 connect tourneo
