Air in Fuel system after replacing leak off pipe
Postby johnsgti » Sun Mar 21, 2010 3:59 pm
Is it possible to damaged the black plastic bits on top of the injectors which the leak off pipes go on to?
Reason i ask is i changed the leak off pipes yesterday, the only reason i changed them is they were very brittle, since changing them it will only run until the fuel filter is empty. Them i have to remove the filter & refill with dev and the same happens again. If i crank an injector open before it cuts out, all that comes out is loads of bubbles.... :?
Van is a 2000 MK5 2.5Di
Ford Transit mk5, 2000 W reg, 2.5di.
johnsgti
