i think we could do with a how too on fitting a 24v cossy
- depending on who gets there 1st
wont be me
- but im at the collecting parts stage i can tell you you will need
an adapterplate - found on svo v6 transits eg amby's or modify a pinto-mt75 one- this is only needed if you want manual.
auto you will need a transit stick,prop, mounting etc and use the granada bellhousing and box(ad4l).
engine mountings- either v6 transit mounts or the later mk5 body mounts using the engine hlaf on the granada mounts.
fuel tank- you will need to modify the fuel tank or fit a dohc one to suit the electric pump.
as for
DOHC - they were fitted to transits from new so the job should be eaiser - the gearbox mt75 is a one off for those vans and would make the job easier
