Auto coversion. Whats involved???
Postby minimadmatt1975 » Mon Mar 22, 2010 1:49 pm
Recently bought 99 mk5 120 swb and wondered apart from the obvious box, prop, pedalbox, maybe starter etc whats involved? Are there any electonics on the later autoboxes and is it going to upset things if i add a turbo to ofset the power loses without ecu etc.
1999 MK5 120 SWB 2.5Di 70ps
minimadmatt1975
Re: Auto coversion. Whats involved???
Postby MinorMatt » Mon Mar 22, 2010 2:16 pm
the mk5 autos are all 85PS turbos and are controlled by the ecu.
If you can find an autobox from a mk3/4 diesel and the torque converter, propshaft, speedo cable, early mk5 speedo assy etc etc it shouldnt be too hard to swap
Postby minimadmatt1975 » Mon Mar 22, 2010 2:28 pm
Thanks, were the mk3/4 all non turbo as i'm wondering if they could take the increased power if i add a turbo. Like your Traveller, i've got a 68 van that i need to restore. Cheers
minimadmatt1975
Postby AlanN » Mon Mar 22, 2010 4:57 pm
You would really want a A4LD (4 speed) autobox rather than a C3 (3 speed) used in the MK3, as for power, they fitted both boxes to the V6's including the Cosworth, so no problem there.
Postby MinorMatt » Mon Mar 22, 2010 5:40 pm
minimadmatt
I have that one, a convertable 2 austin healy sprites and a 1982 mini HL too!
Postby AlanN » Mon Mar 22, 2010 5:46 pm
MinorMatt wrote:minimadmatt
Yer! you and your brother are both Bonkers :lol: :lol: :lol:
Just kidding :wink:
Postby MinorMatt » Mon Mar 22, 2010 5:55 pm
That sounds perfectly reasonable to me Alan....
Postby AndyG » Mon Mar 22, 2010 10:34 pm
8) Makes a change from the usual wanting to go from auto to manual box :!: :D
Postby AlanN » Mon Mar 22, 2010 10:42 pm
I dont think it would be a hard conversion... be a whole lot easier with a donor
Postby AndyG » Mon Mar 22, 2010 10:48 pm
I think the hardest part would be finding a selector, as they're no longer available and the last listed price was :shock: £600 odd :shock: :lol:
The engine will have enough power, but you must take into account that it will feel so smooth, that you actually expect it to go faster, but it won't :!:
:idea: If you do convert, try a 0-30 and a 0-50mph before and after the conversion :idea:
Postby minimadmatt1975 » Sat Mar 27, 2010 1:10 am
Anyone out there with a cheap swb mk4 automatic donor van???? or maybe someone wants to convert to manual mt75??? I'd do all the work and my vans only done 88k. Cheers Matt
minimadmatt1975
