MinorMatt wrote:get the front and rear springs off a 190 then that will get the van higher!
Shockers should be fine
Aardvark wrote:Beware! If you fit a set of 190 springs on your swb you will get more than a higher stance. It will be much stiffer. Great if you carry a load but crap on a wet roundabout or anything other than a dry surface when running empty.
AlanN wrote:Here you go, what 190 leaves could do for you... but in my experiance of driving one, hard as hell when empty![]()
