Engine problem
Engine problem
Postby MWOOLY10 » Sun Jun 04, 2006 8:25 pm
Just wondering if anyone knew what this could be on my DOHC petrol engine
I drove to birmingham loaded all fine this morning then on the way back doing about 80 it would sort of jerk every now and then(The sort of jerk you get when your running out of fuel) and it seemed to use alot more fuel coming back even though it was empty??
Any ideas would be good :)
Cheers Mike
MWOOLY10
Postby Luke » Sun Jun 04, 2006 8:28 pm
ideas :?: well ............... fuel pump :? spark plugs :?:
i had a problem on my sierra same engine - it was the plugs causing it to miss occasionally :!: worth a try cos if it aint that you have a new set of plugs in :idea:
also when you say it used more fuel on the wya back the transit gauge isnt equal - the top half is almost twice the bottom half in real terms :shock:
Postby MWOOLY10 » Sun Jun 04, 2006 8:28 pm
Plus as an after thought anyone got any tips on how to improve fuel comspumtion??
Cheers Mike
MWOOLY10
Postby 100ps_drw_hicube » Sun Jun 04, 2006 8:31 pm
MWOOLY10 wrote:Plus as an after thought anyone got any tips on how to improve fuel comspumtion??
yep superchip :wink: not cheap but more economy and power
100ps_drw_hicube
Transit Abuser!!
Postby MWOOLY10 » Sun Jun 04, 2006 8:31 pm
Luke wrote:ideas :?: well ............... fuel pump :? spark plugs :?:
Oh right..But i normally can gauge how much fuel i'll use going to birmingham and back and it seems to have used a bit more than normal..
As for the plugs i would of thought they were new and i only had a new engine last week..just got it back from having a new crank sensor on it and having a new speedo module as it didnt work..So most if not all the engine should be new now
Cheers Mike
MWOOLY10
Postby MWOOLY10 » Sun Jun 04, 2006 8:32 pm
May have to have a look around :)
AS a thought anyone know anything about these tecnoclean filter things??
Cheers Mike
MWOOLY10
Postby Luke » Sun Jun 04, 2006 8:46 pm
MWOOLY10 wrote:Oh right..But i normally can gauge how much fuel i'll use going to birmingham and back and it seems to have used a bit more than normal..
all tanks are 68 litres - if you get it to half way then fill it to the brim you'll see how far out yours is :idea:
basically i'd have a check round the engine all the usuall suspects plugs, leads dissy cap- anything suspect swap it :!:
i wouldnt assume it's had new plugs unless you know for certain they should look new :D
Postby MWOOLY10 » Sun Jun 04, 2006 8:52 pm
Yeah true..I may run it for another day or two..As its been ok for the last week..Just to see if it runs it in or out if its sh*t somewhere
May have a check out tomorrow now i know its cooled down burnt my bloody hand earlier :lol:
Cheers Mike
MWOOLY10
Postby Valsheda » Mon Jun 05, 2006 6:16 pm
Mate does your engine have injection or is it carbed ????
Only asking cause i had a similar thing happen and mine is injection, so i did the usual checks, plugs n leads etc....but all was ok there so stuck some inj-cleaner in the tank and it was sound after a couple of miles, just a thought :?
Valsheda
Top Tourneo Owner
Postby MWOOLY10 » Mon Jun 05, 2006 11:55 pm
Well it looks like they've reused the injection off my old engine so they might be a little blocked,although it didnt do it before on the old engine..But to try it out i'll stick some redex stuff in
Still needs running in only done a couple of hundred miles so far..
Cheers for that :)
Least i'll know where to come next time i have a query seeing that you have the same engine :lol:
Cheers Mike
MWOOLY10
Postby Valsheda » Tue Jun 06, 2006 10:29 am
Touch wood (hand on head :lol: ) i havent had to many problems, but if i can be of any help give me a yell :D
Valsheda
Top Tourneo Owner
Postby MWOOLY10 » Thu Jun 08, 2006 1:24 am
Found out the problem tonight..Was fine going to Wigan then as soon as i went to go to Birmingham it started again,then stopped then a while later started again..Only seemed to do it on high revs in 4th and 5th..
Was doing my fruit in .. So i put up with it then i hit a bit of traffic so as you do i leaned on the gear stick and it went bananas .. So i think its safe to say that when they fixed my speedo motor last week they didnt put the damn gear box back on properly .. So guess where im going in the morning :roll:
I really enjoy wasting my time and having no van :lol:
anyways just thought id let you know what it was :)
Cheers Mike
MWOOLY10
Postby AndyG » Thu Jun 08, 2006 1:30 am
:shock: Hope it's just an earth :!:
Don't like the sound of a loose gearbox :(
Well done for spotting it :D :wink:
Postby MWOOLY10 » Thu Jun 08, 2006 1:34 am
Well the fuel thing got better as well about an extra 50 miles to a tank which is better than nothing :)
But yeah i was quite pleased as i was p****d off that i found the problem :lol:
Least the place is near to my works so hopefully they can sort it out in the morning..As i need it back to go to High Wycombe on sunday night..and that is too far to be jerked about all night :lol:
Cheers Mike
MWOOLY10
Postby AndyG » Thu Jun 08, 2006 1:38 am
As for the fuel consumption it is very possible that the pump used did not deliver what it said :roll:
My 68litre tank took 78litres one day :!: :lol: :lol: :lol:
