leaking servo.
leaking servo.
Postby detritus21 » Thu Mar 25, 2010 3:17 pm
My MK3 tipper appears to have a leaky servo. Hisses like mad when cold. Stops if you rest your foot lightly on the brake pedal. Are there any seals that can be replaced or common failure areas on the servo that may cause this. MOT is not too far off and need to get it sorted along with the hole in the front cross member.
detritus21
Re: leaking servo.
Postby bortaf » Fri Mar 26, 2010 2:09 am
All my petrol Mk3s did this for years, not had it with a diesel though :?:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Re: leaking servo.
Postby detritus21 » Fri Mar 26, 2010 10:34 am
Originally it was a 1.6 petrol tipper.
detritus21
Re: leaking servo.
Postby topfuel » Fri Mar 26, 2010 10:58 am
hi ! check the rubber seal where the vacuum hose goes into the servo, iv'e had these leak before !
topfuel
Re: leaking servo.
Postby Dave12590 » Sun Mar 28, 2010 2:59 pm
Mine does that too when I break it hisses like mad. Can a new seal be fitted?
Dave
Dave12590
