Also, I believe a mk6 low roof is about 1" short of 2 metres, is this correct?
I think I posted this in the wrong section previously.
Thanks in advance.
The 2 tone money pit.
trigger wrote:Best way to find out is to go out and measure it![]()
trigger wrote:I can measure my van for you if you like, but only when it stops raining
dirtydog wrote:According to my Transit owners guide the roof height of a swb low roof 80-150 is between 1964mm - 2043mm depending on the model
MinorMatt wrote:yes
120s are pretty high at the back... Having said that when you put a load in it it will get lower
