I was taking my old Manual Pump off my MK 5 Turbo to replace the pump with a Re-Con 146 Bosch then found an oil leak from between the main block and the head. It is only a little leak but, is it going to get worse? And if it is-is it best to remove the head and replace the gasget?
The Engine runs sweet, never smokes, could it be a duff gasget?
Also there is some oil on top of the head by the injectors but i think this is a leak from the breather pipe?? It isn't the rocker cover because that has a new gasget 2k aga. Will take the manifolds of the top of the engine tonight to get a better look.
Suggestions??
Pick is of the leak right where the pump is (was)
MK 5 TD Transit 80 SWB Custom with Air Con. Gone, Lost to fire.
MK 7 110 FWD MWB Blue Camper conversion.
Mk 7 110 FWD MWB Dark Grey Limited van.
Mk8.5 Ecoblu 350 ex Amazon 71 plate with All of the dents..
