confused?!?!?!
confused?!?!?!
Postby edna » Thu Apr 01, 2010 8:50 pm
i bought a p reg mk5 transit and didnt think any more about it but i put a mess grill in and relised the grill doesnt fit not even close and the dash is slightly different so now i wonder if its a mk4 in disquise lol please help me is there a way to tell???
edna
Re: confused?!?!?!
Postby Luke » Thu Apr 01, 2010 8:56 pm
the grills fit on mk4/5's as they both have the same headlights - has the dash got the cup holder and the document clip holder on it :?: also does it have vents in the back panels near the rear doors :?:
Re: confused?!?!?!
Postby AndyG » Thu Apr 01, 2010 10:18 pm
Registration and or chassis number :?:
Re: confused?!?!?!
Postby trigger » Thu Apr 01, 2010 10:35 pm
P reg sounds a bit too late to be a mk4
Mk5 Transit the daddy
trigger
Re: confused?!?!?!
Postby edna » Fri Apr 02, 2010 9:10 am
Yes it has got the empty hole where the cup holder should be and the document clip and the vents at the back
edna
Re: confused?!?!?!
Postby Luke » Fri Apr 02, 2010 9:47 am
sounds like a mk5 to me :D
Re: confused?!?!?!
Postby edna » Fri Apr 02, 2010 12:23 pm
cheers well on the back of the grill the 2 metal supports one fits fine then the other doesnt even nearly fit but there is no modifications to it that i can see :?
edna
Re: confused?!?!?!
Postby AndyG » Fri Apr 02, 2010 12:37 pm
The passenger side one has two positions and the support/strut is different.
Is it on the inner or out hole fixings of the grill :?:
Re: confused?!?!?!
Postby edna » Fri Apr 02, 2010 12:56 pm
its on the inner one and the drivers side one is still far towards the wing :?
edna
Re: confused?!?!?!
Postby AndyG » Fri Apr 02, 2010 1:01 pm
That sounds correct for a standard (no air con) van :D
Any pictures :?: as I can't understand why it doesn't fit :?
Re: confused?!?!?!
Postby edna » Fri Apr 02, 2010 7:25 pm
i had another look today and i bent it slightly now it fits better i think it was just bent :)
edna
