rev counter
rev counter
Postby maxlee » Wed Jun 07, 2006 5:01 pm
i no this has been posted over a milon times befor and i am sorry for all the people that are looking at this thinking "ahhhh not again" but i have a fue Q's
as normal found a scraped mondao 1.8td thought ah i'll have the clocks as they were driven by a spedo cable
got them home swapped them over and no rev gage :cry: my alternater has 3 wires on it gray , blue/black, big black wire. the van is 95 on a N
any one tell me if i have missed som e thig i have to do?
when i plug the clocks in i get a sport light that comes on so i'll be leaving that blub in there lol must add more bhp then neons coz it says sport :lol:
maxlee
Postby AndyG » Wed Jun 07, 2006 5:18 pm
If the "sport" light is on for no aparent reason just pull the bulb out :D
Rev counter :roll:
Make sure you have the White cable with a black stripe going to pin 8 of the larger connector :wink:
If you don't (as I suspect) you'll have to run your own :!: :D
Postby motorwise » Wed Jun 07, 2006 6:29 pm
the illuminated sports light is worth an extra 10-12 imaginary BHP - I'd leave it in :wink:
http://www.motorwise.net
motorwise
Postby maxlee » Wed Jun 07, 2006 9:20 pm
motorwise wrote:the illuminated sports light is worth an extra 10-12 imaginary BHP - I'd leave it in :wink:
thats right no more down changing for me on hills when that baby is lit up
were dose the wight and black wire have to come from befor it goes in to rev counter :oops: is it the midle pin on the alternater? (just a gess to try and make my self sound smart :lol: )
maxlee
Postby AndyG » Wed Jun 07, 2006 9:31 pm
Nooooooooooooooooooooooooooooooo :!:
Go take a look in the Tech section :!: It's shorter than the "Mondeo Dash again"
There's piccies there too :D
Postby maxlee » Fri Jun 09, 2006 11:26 am
Note:-On 95+ Transit diesel the rev counter will work straight away as long as there are 3 wires on the bolt on terminals on the alternator,the big wire,charging,the bluewire,dash warning light,the third, grey if my memory serves me, rev counter.if it only has 2 wires, no rev counter
going to read the othere post if i get through the 10 pages :lol:
Image whats this bit for on the transit speedo we swapped it from the transit one to the othere one and i think it is for the fuel gage as it gave a higher reading then befor
Look at your large connector socket, look carefully next to the pins they are numbered. You need no. 8. Mine has a white and black coloured cable going to it. Hope this helps. Andy.
so looks like its a trip down the scrap yard to get the othere block of the car the clocks come out of is it the bigger one of the the to in the van that needs the wire feeding to it?
as some one said in the othere post think the how to tec post on this needs up dating :lol: as you can have the 3 wires on your alternater but its still not plug and play
maxlee
Postby AndyG » Fri Jun 09, 2006 1:25 pm
"three wires but not plug and play"
Because the third wire might simply terminate at the large connector next to the battery :!:
If you have a look at the photo with the plugs, the larger connector is the one you need to count from the bottom and you will see the white/black cable :D
