Rear Shock upper mount problem
Postby WildGoose » Wed Apr 14, 2010 8:19 pm
Found this today while I thought I would have a quick check on the rust situation under the van. I'll let the pictures to the talking.
Now clearly this isn't right, but I was wondering what I need in order to sort it. Is there supposed to be a rubber/metal bush in there, has it failed and fallen out/crumbled away.
Or is the shock a one piece thing?
Will the shock be nackered now.
Thanks for any advice, as always. :)
WildGoose
Re: Rear Shock upper mount problem
Postby WildGoose » Wed Apr 14, 2010 8:20 pm
Oh, its a '98 MK5 SWB 80 :wink:
WildGoose
Postby Altransit » Wed Apr 14, 2010 8:23 pm
Yes, the shock mounting bush has worn away :(
You may be able to get a new bush and replace it, but it may be easier to replace the shock :wink:
Postby WildGoose » Wed Apr 14, 2010 9:08 pm
You may possibly be right, bushes can be a sod, especially if the remnants are still in there.
Is it usual practice to replace shocks in pairs? Similar to brakes; to keep the balance right, or is changing one perfectly acceptable?
WildGoose
Postby Altransit » Wed Apr 14, 2010 9:10 pm
Personally ................... I would change both :P
Postby WildGoose » Wed Apr 14, 2010 9:11 pm
Thats cool, a quick look on ebay says they aren't too pricey.
Last question, any recommended suppliers? :wink:
Thanks so far :D
WildGoose
Postby Altransit » Wed Apr 14, 2010 9:15 pm
The likes of Monroe and Spax make some of the best ones, but I would plump for the ebay ones for a van. Ford can be surprising with prices sometimes ................. worth checking first :wink:
Postby WildGoose » Wed Apr 14, 2010 9:20 pm
Cool, cheers. :)
If I could afford such things as cookies you would be recieving some. :lol:
WildGoose
Postby Altransit » Wed Apr 14, 2010 9:23 pm
WildGoose wrote: If I could afford such things as cookies you would be recieving some. :lol:
:lol: Thanks mate Image
