minimadmatt1975 wrote:I was thinking valve stem oil seals but you say the cloud is grey not blue. Valve stem seals normally cause blue smoke at cold start but unless valve guides badly worn stops. Does it use much oil? If not maybe just running rich at idle. Sticking vv autochoke perhaps.
johny transit wrote:Surely a 2 litre dohc would be the way forward if you intend to replace the engine? Much more power, better economy and prolly more readily available than another pinto? Don't go for a diesel they are SO noisy!
