Front hub noise
Front hub noise
Postby ginsambo » Thu Apr 22, 2010 6:34 pm
I really need to take the time to do some work on my tipper and have been overloading it slightly of late. Apart from my knackered thrust bearing and gearbox low on oil, I've discovered a new freewheeling noise coming from the nearside hub, kind of like a brake binding noise or knackered wheel bearing like something is scraping. Haven't jacked it and rotated the wheel yet as I'm too lazy or busy. Is this time for new wheel bearings you think anyone? Should I look at it ASAP or could I leave it a while without the hub falling off? - Doesn't seem like too much play in the bearings at present. Got an MOT two months ago and they said to tighten the bearings but that's just usual with a transit as they wear. I never did get around to it though. :roll:
Can anyone advise? Thanks.
ginsambo
Re: Front hub noise
Postby JohnTransit97 » Thu Apr 22, 2010 10:08 pm
Hi ginsambo
Had the same problem with our Ford Transit SWB minibus97 we left it go for about 3months even though the noise got gradually worse over time.I thought the same that the hub may well fall off. Have now repaired the problem with the great help from this forum. I would try and get it done asap.
I went to local motor factors and had 2 bearing kits for about £20 maybe a little more.
JohnTransit
JohnTransit97
