HI
I looked at this wedsite when i was after the back pipe on my mk 5 Turbo conversion, the van i have is a 97 van. With a 1999 front pipe with cat... I looked through the picks and found the part numbers for a back pipe on a pre 98 swb td van.
If you look at the picks on the links below you can work out the type you need.
The Front pipe on the T reg van you have had a cat on it. The First link is the system on the T reg van.
I used the part code and went to CES (Chester exhaust centre) and got the back pipe from there.
The Flange on the front to middle pipe will be the wrong way round but you could just cut/weld the other way round. If you are planning to use the exsisting exhaust! And if they join under the driving seat area under the van!!!
Hope this helps!!
http://www.cats-direct-shop.co.uk/exhaust-systems.php?recordID=1208http://www.cats-direct-shop.co.uk/exhaust-systems.php?recordID=1207
MK 5 TD Transit 80 SWB Custom with Air Con. Gone, Lost to fire.
MK 7 110 FWD MWB Blue Camper conversion.
Mk 7 110 FWD MWB Dark Grey Limited van.
Mk8.5 Ecoblu 350 ex Amazon 71 plate with All of the dents..
